I am using Symphony xplorer w35.
I wanted to install a custom ROM on it, so I backed up the the original ROM (normally, without using CWM recovery). After that, I installed CWM recovery mode on it. Then, I wiped my data & cache and installed a custom ROM, but I forgot to backup the previous ROM using CWM! Now, when I wanted to restore the previous ROM, it is impossible!
The previous backup is a .backup file & CWM can't restore it. I have to restore it via normal recovery mode, but whenever I turn on recovery mode, CWM mode automatically comes there! How to restore my previous ROM?
  • Usually you can download the stock ROM from your manufacturer's website. – ott-- Jun 15 '15 at 20:37
  • Use Sp Flash tool to flash Stock ROM on your device. Then restore the backup using the normal Recovery. It will work. Here are the instructions. – Firelord Jun 16 '15 at 01:16
Here you can download the stock ROM for your device: Stock ROM for Symphony Xplorer W35
Instructions:
How to Flash
Step 1: Download and extract the stock firmware on your computer.
Step 2: After extracting you will find the SP Flash Tool, Driver and instruction manual.
Step 3: Install the USB Drivers (skip if drivers are already installed).
Step 4: Open the SP Flash Tool and load the Scatter File from the firmware folder.
Step 5: Connect your Smartphone to the computer using the USB Driver.
Step 6: Click on Upgrade / Download Button in the SP Flash Tool to Begin the Flashing.
Step 7: Green Ring will appear at the end of successful Flash.
For more detailed instruction with images: Detailed Instructions with Images
Source: http://xdafirmware.com/symphony-w35
Hope my answer helps!
Thomas Vos
  • 4,000
  • 35
  • 46
