I have an Android device which does not have place to insert a SIM card, can I tether this device to PC through USB (I want it to be fast, hence preferring USB over Wifi) in some way?
Asked
Active
Viewed 2.1k times
I think this question is extension of that Cam software question. So, do you not see the tethering option in your device? Which device and Android version is it? – Firelord Jun 04 '15 at 16:31
Yes. I do not see tethering option. This a Epson Moverio BT-200, its AR glasses. Android 4.0.4 – Aparajith Sairam Jun 04 '15 at 16:36
If your device does not have tethering built in (Many devices do), you can get an app from the Play Store that allows you to tether your phone. There are several great applications that allow you to tether via USB or WiFi. A good app that solves this purpose is one called USB Tether https://play.google.com/store/apps/details?id=com.mkdev.usbtethering2 Its simple and functional.
Dheeraj
- 164
- 1
- 1
- 5
There is an app whose minimum requirement is Android 4.0.3 . This app doesn't even require root access.
Install this application which will help you achieve USB tethering.
https://play.google.com/store/apps/details?id=eu.chainfire.hotspotcontrol&hl=en
reachrk
- 736
- 1
- 6
- 19
1For some reason, Hot Spot didn't work in the Android device. We used FoxFi. – Aparajith Sairam Jun 08 '15 at 13:27
