I have a Lenovo s890 that sometimes stop responding and back after about 1 minute. I have checked the screen and seem there is no problem with the screen. On the other hand when the cell phone stops working, then the battery indicator drops significantly that is really annoying. Do you have any solution for that?
Here you can a similar video that shows the problem. https://www.youtube.com/watch?v=FB_w4WvDiUY
TPArrow
  • 101
  • I guess you're unaware of the distinction between a forum and a Q/A site. Consider taking a tour and a glance at [help]. Look especially about self-answer. – Firelord Jun 01 '15 at 18:27
  • Hi @Firelord. Thanks so much I know the difference but finding solution in forums is so difficult at least for me but in SE it is much much easier. It is the main reason I decided to post the solution here. Thenks. – TPArrow Jun 01 '15 at 18:30
  • No issues in posting a solution but as per the rules, a question field should only have a question. You can always answer your question in the answer tab. Please [edit]. – Firelord Jun 01 '15 at 18:31
  • See this question as an example of self-answering. I had the same reason for doing it. – Firelord Jun 01 '15 at 18:32
I played more than 3 months with the mobile phone and this is how to solve the problem. I Guess this solusion works for other mobile phones.
If you have a lenovo s890 (or other cellphones with similar symptoms) that sometimes stops and not responding or if your battery drains suddenly or if the screen goes off and does not back, then the problem is not with battery or screen. I have seen some people that asks for help and there are loads of solution that none of them work. The solution is a problem in the kernel of OS that manages CPU of the cell phone.
First install a CPU manager app from google play for example (link). Then Decrease the maximum CPU frequency to one level down and set the governor to Ondemand (like screenshot)screenshot.
I have tried other setting that none of them worked for me.
TPArrow
  • 101
