My Nexus 4 fails to mount with mtp mode. All other modes work (ptp, adb, fastboot). Three months ago I was able to copy the /storage/emulated/0 directory from the Nexus 4 to my pc for backup so all worked then. I was running the same systems then as now, Ubuntu 13.04 and Cyanogenmod CM11 M12. I have rebuilt the phone with no success. I have tried two other PC's running Ubuntu 13.04 with no success. There is no change in the response to "mount" before and after connecting the phone. The phone correctly shows "Connected as a media device". The response to "lsusb" correctly shows the phone connected:
jim@Toshiba-Satellite-M35X:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 046d:c00c Logitech, Inc. Optical Wheel Mouse
Bus 001 Device 005: ID 18d1:4ee1 Google Inc.
Using "mtp-detect" I get the following response:
jim@Toshiba-Satellite-M35X:~$ mtp-detect
Unable to open ~/.mtpz-data for reading, MTPZ disabled.libmtp version: 1.1.6
Listing raw device(s)
Device 0 (VID=18d1 and PID=4ee1) is a Google Inc (for LG Electronics/Samsung) Nexus 4/10 (MTP).
   Found 1 device(s):
   Google Inc (for LG Electronics/Samsung): Nexus 4/10 (MTP) (18d1:4ee1) @ bus 1, dev 3
Attempting to connect device(s)
Android device detected, assigning default bug flags
USB low-level info:
   Interface has a kernel driver attached.
   bcdUSB: 512
   bDeviceClass: 0
   bDeviceSubClass: 0
   bDeviceProtocol: 0
   idVendor: 18d1
   idProduct: 4ee1
   IN endpoint maxpacket: 512 bytes
   OUT endpoint maxpacket: 512 bytes
   Raw device info:
      Bus location: 1
      Device number: 3
      Device entry info:
         Vendor: Google Inc (for LG Electronics/Samsung)
         Vendor id: 0x18d1
         Product: Nexus 4/10 (MTP)
         Vendor id: 0x4ee1
         Device flags: 0x08008106
Configuration 0, interface 0, altsetting 0:
   Interface description contains the string "MTP"
   Device recognized as MTP, no further probing.
Device info:
   Manufacturer: LGE
   Model: Nexus 4
   Device version: 1.0
   Serial number: 00364595560f4a2f
   Vendor extension ID: 0x00000006
   Vendor extension description: microsoft.com: 1.0; android.com: 1.0;
   Detected object size: 64 bits
   Extensions:
        microsoft.com: 1.0
        android.com: 1.0
Supported operations:
..........etc.
Does anyone have ideas on what to do next?
bmdixon
  • 8,815
  • 43
  • 64
Jim
  • Do you strictly want this MTP for some purpose, or would an alternative would suffice as well? This site has answers for the alternative in case you need them. – Firelord May 28 '15 at 16:42
  • @Firelord I don't have to use MTP although it was very easy when it worked. It would be nice to figure out why it dosn't work now. Would you point me toward some alternatives that I can evaluate. – Jim May 29 '15 at 02:35
  • It would be good if MTP works out, otherwise you may consider the alternatives mentioned in this question. – Firelord May 29 '15 at 12:11
It seems you're on linux. If you're on debian or a derivative of it, try sudo apt-get install mtpfs. If you are on some other distro, try installing the mtpfs or libmtp package. Then reconnect your phone and it should work. This worked for my Moto E2 and G2 on Ubuntu 14.04
Chipset
  • 172
  • OP is running Ubuntu 13.04 and Ubuntu is a derivative of Debian, and is a GNU/Linux. That said, OP did say that MTP was working fine three months ago, which means MTP packages are already installed. OP also mentioned mtp-detect. Are you saying mtpfs or libmtp is different from those installed packages? – Firelord Jul 05 '15 at 18:07
  • I'm not sure if they are same or different, but my stock nexus 4 worked without installing the packages. I got an E2 and G2 recently, and they weren't working out of the box. I installed mtpfs and they've been working since then, and nexus 4 too – Chipset Jul 05 '15 at 18:10
