i'm studying a resnet50 tutorial, which contains the following piece of code
def create_dataset_cifar10(dataset_dir, usage, resize, batch_size, workers):
data_set = ds.Cifar10Dataset(dataset_dir=dataset_dir,
                             usage=usage,
                             num_parallel_workers=workers,
                             shuffle=True)
trans = []
if usage == "train":
    trans += [
        vision.RandomCrop((32, 32), (4, 4, 4, 4)),
        vision.RandomHorizontalFlip(prob=0.5)
trans += [
    vision.Resize(resize),
    vision.Rescale(1.0 / 255.0, 0.0),
    vision.Normalize([0.4914, 0.4822, 0.4465], [0.2023, 0.1994, 0.2010]),
    vision.HWC2CHW()
I'm aware that normalization is an important step of data pre-processing. I'd just like to know where do the values such as 0.2023 come from.
Some friends guessed the values referred to the means and standard deviations of the dataset. The following code is to verify the assumption.
(train_images, train_labels), (test_images, test_labels) = datasets.cifar10.load_data()
train_images, test_images = train_images / 255.0, test_images / 255.0
all_images = np.vstack((test_images, train_images))
reshaped_images = np.copy(all_images) reshaped_images = reshaped_images.reshape((3, 60000, 32, 32)) reshaped_images = reshaped_images.reshape((3, 60000 * 32 * 32)) print(np.mean(reshaped_images, axis=1)) print(np.std(reshaped_images, axis=1))
gives
[0.47562782 0.47245647 0.47361567]
[0.25186847 0.25178283 0.25087802]
while
reshaped_images = np.copy(train_images)
reshaped_images = reshaped_images.reshape((3, 50000, 32, 32))
reshaped_images = reshaped_images.reshape((3, 50000 * 32 * 32))
gives
[0.47410759, 0.4726623 , 0.47331911]
[0.2520572 , 0.25201249, 0.25063239]
neither is consistent with 0.2023
JJJohn
  • 221
These are the precalculated values over the train split of the CIFAR10 dataset.
See this link, for example. You can try calculating these values for yourself to see if they match up.
Alexander Wan
  • 1,254
They should be the means and standard deviations over the RGB channels of images in the training dataset
Karl
  • 206
