I am trying to find a doctoral program without a capstone, project, or a dissertation, because I do not find a value in doing a project.
But why isn't there a doctoral degree that does not involve a major project?
The doctoral degree indicates that you are ready to "do research" yourself. A Ph.D. (or similar doctoral degrees) is essentially your qualification to join the academic community as a fully fledged researcher. Until this time, your research, e.g., for a Master's thesis, was conducted under close supervision by your professor.
The community believes that the best way to find out whether you can conduct a research project yourself is, in fact, to have you conduct a research project yourself. This is what the dissertation is all about. (Of course still under supervision - after all, you are still learning the ropes.)
No amount of classes or coursework will prepare you adequately for the realities of research, just as you can't get a driver's license through a written test only, without demonstrating that you can indeed drive a vehicle.
I strongly recommend that you reexamine the value you may see in a doctoral project.
So first we have to distinguish between PhD's and the EdD, MD, JD type of degree.
If you are getting a PhD in something then you are the world expert on that narrow topic. That is the point of the PhD, at least in the sciences. You need to be able to solve a problem no one has solved before. You have passed your professors. Some fields, such as engineering, use some form of project rather than a written document.
The coursework is designed to prepare you to begin your doctorate. You are used to undergraduate or masters programs where you take a class and learn something. The purpose of the courses is to add to your personal knowledge in the topic. In a doctorate, the purpose of the courses is for you to learn how to think about problems. In some fields, such as accounting, the content knowledge is pretty much complete at the masters level. A PhD in accounting isn't about knowing more knowledge in accounting, it is about researching the consequences one accounting standard has on society versus another.
Most people never finish their dissertation who get through their coursework. There are two possible reasons. The first is a lack of discipline and commitment, but the second is that you have chosen a problem that you cannot solve. Generally you could avoid the second by being careful, but it does happen. A PhD is intended to be risky.
The EdD, MD and JD and a handful of similar professional degrees substitute rigour, exams and methods to show they have sufficient expertise in their fields that they no longer need supervision or their fields require postgraduate supervision and so in some fields, such as medicine, the doctorate is granted prior to the "project." It is not enough to have an MD to practice medicine as an independent person. You then need to pass an exam, then get an internship, then pass another exam, then become a resident, then pass another exam then become a practitioner and possibly specialize and take yet more exams to show you could be a "fellow," in a professional society. You will then take continuing exams to show you should still be practicing.
So, in medicine, the MD is granted before the "dissertation" phase.
The courses in a doctorate are not there to teach you everything you need to know. They are there to prepare you to know how to learn on your own, everything you need to know.
