26
I reviewed a research paper and found it to be well-written with no technical or language issues. How should I go about writing the review report for the paper?
If I write something on the lines of "the work is well-written and well-presented" and keep the review report succinct, I am worried that the editor might think I did not review it critically.
user3024069
  • 1,373
    I have written some fairly short reviews in my time. Particularly for good papers they will not come as a surprise to the editor. – Jon Custer Nov 22 '19 at 18:00
    Don't forget to include a summary. And mention what they did so good. –  Nov 22 '19 at 18:08
    I've had papers rejected where one reviewer was negative and verbose and one reviewer was positive and succinct, even when the negative points raised were either incorrect or easily clarified/corrected. I presume, though I can't know for sure, that the difference in length influenced the editor. – Bryan Krause Nov 22 '19 at 20:59
    Do you have review reports others have written about your work? Those can be a good starting point to figure out how a good review report is written. – Snijderfrey Nov 22 '19 at 21:41
6 Answers6
52
Just being well-written and correct is not enough. Why should someone read the paper? What are the new things that we learn thanks to this work? Why is it exciting, interesting or useful? Why should we care about it so much that it should be published in a journal? How is it advancing science? What was the state of the art before this work, and how did this paper change the world?
In your review, you should explicitly recommend either acceptance or rejection. If you recommend acceptance, your review has to convince the editor that the paper is indeed worth accepting. (Similarly, if you recommend rejection, you will need to convince the editor that the paper should not be accepted.)
Jukka Suomela
  • 6,502
  • 28
  • 32
    your answer sounds like the associate editor doesn't or isn't supposed to overtake or judge any of the points mentioned in your first paragraph. It's not like the associate editor has no background in a field, often he is a professor in my field with much more historic overview than the reviewers being topical experts. Also, good journals nowadays have a very extensive rating system parallel to the written comments of the reviewer. I'm wondering how often an associate editor is not starting peer review process and rejecting at a first glance due to not reaching journal standards formally. – user48953094 Nov 22 '19 at 22:32
    Personally I think it is the decision of the editor if a paper is exciting, interesting enough for that journal and I'm not inclined to say it should be highlighted or not but stay neutral as a reviewer and foster to push my trendy topic or citation cartels. Reviewing for soundness, novelty is my job, everything else I don't care too much. In general I think your answer is too much black & white. – user48953094 Nov 22 '19 at 22:35
    @user48953094: Most editors do not have enough time to read all the papers they are responsible for and decide if the paper is interesting enough for the journal. They rely on reviewers to give them a summary of the paper and its merits to help them reach this conclusion. – Alexander Woo Nov 22 '19 at 23:50
    @AlexanderWoo see my question here: https://academia.stackexchange.com/q/140484/41661 The question is why I as a reviewer or the (unpaid) associate editor should overtake this task concerning the prices for journal articles. "It was always like this" is no good answer anymore... – user48953094 Nov 23 '19 at 10:55
    Reviewing for soundness, novelty is my job, everything else I don't care too much — Too bad. The editor asked you for your professional judgment whether the paper should be accepted. You agreed. So you have a professional obligation to provide that judgment. – JeffE Nov 23 '19 at 18:06
    @user48953094 quite on the contrary, any editor can see whether it's well written and reasonable, but the decision on whether the research is novel and important for the subfield is something where specific expert reviewers opinion – Peteris Nov 23 '19 at 19:42
15
If this concerns you, write something like:
This paper uses X to investigate Y. It is well-written and the conclusions are backed by the experiments performed. I have no concerns and recommend acceptance as-is.
Allure
  • 127,528
  • 50
  • 325
  • 493
There is no such thing as a perfect paper. Even when a paper is technically sound and written in perfect English, there usually is something like an explanation that could have done better, a confusing notation, a missed connection to existing work, or a misleading emphasis in the abstract. You probably know this from your own writing that no matter how often you revised it in response to constructive critique, a reviewer can point out some obvious (minor) improvement.
As a consequence, when I am reviewing a paper (that I had not seen before) and had nothing to remark for a few paragraph, this is very likely because I became unfocused. When I receive a paper from internal review without any comments, I am suspecting that the reviewer did not put much effort into it.
And if I were an editor, an otherwise all positive review (as you are about to give) would carry more weight for me if accompanied by a list of minor issues. This demonstrates that the reviewer actually thoroughly and critically read the paper. It also somewhat makes it less likely that the reviewer is just blindly recommending acceptance of a crony’s paper. One of my own papers was clearly subjected to one more review than usual for the respective journal after receiving a short exclusively positive review.
Now, it is of course impossible to know the editor’s stance on this, unless you intimately know them. Also, things may be a bit different, if you have a reputation as a thorough reviewer and the paper in question is written by your known arch-enemy. However, I consider it unlikely that a paper’s chances are diminished by a list of minor issues clearly labelled as such. This should of course be accompanied by the things mentioned in the other answers:
  • A summary of the paper in your own words.
  • A short list of technical highlights of the paper.
  • A short evaluation of the paper’s importance (unless the journal in question explicitly does not care abut novelty/impact).
Wrzlprmft
  • 61,194
  • 18
  • 189
  • 288
A short letter saying the paper is correct and well written is OK.
The editor may want your opinion about whether it's important or interesting enough to meet the standards for this particular journal. Check your instructions.
Ethan Bolker
  • 35,457
  • 82
  • 127
You should go with what @Jukka Suomela suggested: explain why the paper is interesting, why someone should read it, etc. But there is another thing -- in my field, reviews often start with a few paragraphs that quickly summarize the work being discussed (usually in a pretty neutral way). This allows the reviewer to recap what they understood about the work, gives authors and others a chance to see if they misunderstood something -- and yes it also makes the review more substantial.
So in addition to positive feedback about the work, you can consider also including your own quick neutral summary of what you understood from the work.
a3nm
  • 3,932
The answer of Jukka Suomela was very nice and comprehensive. However, I would like to add some remarks.
Remember that there was a reason that the editor has chosen you to be the reviewer of the paper. Because he/she found you an expert in this scientific field not in the language or the technique of writing. Therefore you should be very strict about reviewing the paper and give feedback on every aspects of the study, including the literature, the novelty of the work, the details of the experiment (or the method that they have used), the flow of the paper, the language, etc.
Even if you find the study sound in every manner, which is very rare, then it is strongly recommended to write a paragraph about the study at the beginning of your review. This clarifies everything and then everyone understands that you have reveiwed the paper in a correct manner.
Good luck
KratosMath
  • 1,034
