86
Let's say Alice has written a paper that attacks a well-known problem in a clever new way. Her paper ends with "these methods work up to N = 10; for larger N, the calculations are prohibitively expensive".
Bob reads the paper and successfully duplicates Alice's results, but where Alice only had access to a 4-core desktop, Bob has a 4000-core supercomputer. Therefore he can calculate what Alice found prohibitively expensive, and get results up to N = 20.
Are Bob's results publishable? He didn't actually do anything special, he just had more computational power. On the other hand, the results are definitely new, and interesting (for whatever reason N = 20 is the point where interesting effects are predicted).
If they are publishable, what would Bob actually write in such a paper? Everything sans the result could effectively be communicated in one sentence ("Read Alice's paper"). If they are not publishable, how is Bob to communicate his results to the wider world?
I suspect something like this has happened in the past, in which case I'd appreciate a link to such a paper.
Allure
  • 127,528
  • 50
  • 325
  • 493
    I’m pretty sure that if Bob did write a paper about something like this, it’d include the standard sections (e.g. abstract, introduction, methodology, results, conclusion), and cite Alice in the introduction where he’s providing context about the research problem and why it’s important. – nick012000 Nov 13 '19 at 03:21
  • 54
    I don't think this is exactly what you're looking for, but this paper was only possible because of increased computational power, and almost any first-year CS undergrad today could write the program to do the search. – chipbuster Nov 13 '19 at 03:27
    Many results at the Large Hadron Collider were achieved 'simply' because they had a bigger particle accelerator. Perhaps there is a parallel there? – Time4Tea Nov 13 '19 at 14:29
    @Time4Tea You juuust beat me to it! Maybe I can write a longer comment? I was trying to remember the name of the next-largest collider that the LHC surpassed. – user3067860 Nov 13 '19 at 14:31
    At the very list, Bob replicates Alice's results. Depending on the results, that might not be trivial and thus be valuable – Syfer Polski Nov 13 '19 at 17:59
    Check out the Sum of Three Cubes. It took increased computing power to find the solutions for (in order of discovery) 33, 42, 906, 165, and (a non-trivial) 3 (all of them this year and requiring over five million computing hours combined). – Draco18s no longer trusts SE Nov 13 '19 at 19:15
  • "If they are not publishable, how is Bob to communicate his results to the wider world?" Really? These days I read just as much interesting stuff on people's private blogs as I do in academic papers. Publishing on your blog, or on medium, or other sites.... is publishing, even if it is not peer-reviewed academic publishing. – Paul Nov 13 '19 at 21:25
    @chipbuster: I have a colleague whose tenure application got held up because non-math people on the promotion committee considered his couple-page math publication to be unacceptably short. I wonder how that example would play out in this context. – Daniel R. Collins Nov 13 '19 at 22:30
    Probably the most famous example is the four color theorem – BlueRaja - Danny Pflughoeft Nov 14 '19 at 01:37
  • I would say they're not publishable just because more cores were used, but they're probably publishable because they provide an additional insight, such a lower uncertainty. – Jake Nov 15 '19 at 20:43
  • In machine learning, more compute-associated results are publishable. If you've been following recent work in natural language processing, the amazing progress on language benchmarks can be in-part attributed to throwing more compute at the problem. BigGAN showed that dramatically scaling up a baseline method was able to significantly improve the state of the art in creating realistic images from random noise. A key distinction is that these methods did make non-trivial changes while scaling up. Rich Sutton wrote a nice essay on this: http://www.incompleteideas.net/IncIdeas/BitterLesson.html – ligamentous_creep Nov 17 '19 at 23:07
8 Answers8
74
(I switched the order of a couple of your questions to give the answer a more logical flow.)
If the results are new, and interesting, then they are by definition publishable. The key point is they add something meaningful to the sum total of human knowledge. That’s certainly a sufficient criterion for publishability (in an idealized sense it should be necessary as well, but I fear it isn’t - plenty of things get published that don’t really meet this condition).
The concept of “doing something special” is both mostly meaningless and (to the small extent that it has any meaning) completely irrelevant to the question of publishability. Plenty of authors of excellent papers “didn’t do anything special” - they just had more patience and were willing to work a bit harder, or in many cases just got a little bit luckier, than their peers, and ended up discovering something significant. Publication is not a prize that’s given for “doing something special”, it’s simply the scientific community putting a stamp of approval on a discovery that it is correct, new, and worth paying attention to.
By the way, one can even say that a researcher Bob who works harder than his peer Alice is pretty much the exact scenario you are describing of someone “having more computational power”. In this case the computational power is of the human sort, but I don’t see why that should change the calculation.
Edit: another thought is that Bob actually did “do something special”. It’s not just that he had more computational power, but he had the foresight and intuition to realize that it would be worthwhile to apply that computational power to Alice’s particular problem rather than spend his time and resources doing any number of other things. So although it’s not really that important as I said above, even by your own criterion I think there is more merit to the achievement than your description makes it sound.
Bob would simply write what he did and what the results were, and what makes them interesting. If it can really be described in one sentence I’d argue that it likely wasn’t such an interesting result after all. But on the off-chance that it was indeed interesting, then it would make for a great one-sentence paper. There isn’t any rule that papers have to be longer than one sentence.
Dan Romik
  • 189,176
  • 42
  • 427
  • 636
  • I remember reading a list of the shortest published papers. (paraphrased) "Here is how to do X with Y units: " (this was a mathematical paper for quite a simple problem) – user253751 Nov 13 '19 at 13:03
    +1, but I think you misinterpreted the OP a little in your final paragraph. OP knows that the results probably need more than one sentence - "Everything sans* the result* could effectively be communicated in one sentence". The one sentence OP refers to is the one that references the previous paper, rather than rewriting what has already been written there. – JBentley Nov 13 '19 at 13:46
  • @JBentley the wording is a bit ambiguous so I can’t be sure what OP meant exactly, but it looks like they are wondering how a paper can be written about the new result when essentially all there is to say about it is “Read Alice’s paper and set N=20.” What I wrote in my answer corresponds to that interpretation of the question. But yes, I can see that you have a point and that the paper may end up having some additional content describing why the N=20 result is significant, etc. – Dan Romik Nov 13 '19 at 15:36
    It seems interesting (for once!) to consider edge cases. Suppose for instance that Alice's paper contains a link to code, and Bob downloads the code and uses it on his computer without change. Then it seems that Bob has no intellectual contribution and should not write a paper. As for having the insight to devote his resources to it: well, maybe Alice's hiring committee should be authors on her paper? Or the governor of the state if she is at a state university? And so forth. – Pete L. Clark Nov 13 '19 at 18:12
    @PeteL.Clark I’m not really into analyzing such how-many-angels-can-dance-on-the-head-of-a-pin-type hypotheticals myself, but I‘d be happy to read an answer discussing this if you’d care to write one. – Dan Romik Nov 13 '19 at 18:27
    Got any examples of one sentence papers? I think "This repeats Alice's paper with N=20. " Together with all the expanded tables and charts is likely to be desk rejected. My experience is that editors and referees will make you write at least a halfway decent literature review (or cite some), explaining the previous work and why going from N=10 to N=20 allows comparison of theories, resolves a controversy, or is otherwise an interesting thing to do. – Paul Nov 13 '19 at 21:37
  • @PeteL.Clark I'd definitely be interested in an answer that deals with those edge cases, especially the first one (Bob downloading Alice's code and running it was what I was thinking of when I wrote the question)! – Allure Nov 14 '19 at 06:36
  • 'There isn't any rule that papers have to be longer than one sentence' - this reminded me of something interesting I found a while ago - http://tinytocs.org/ a sight with 140 char or less research papers in Computer Science - does this count for examples @Paul ? – Cinderhaze Nov 15 '19 at 17:26
  • @Cinderhaze Interesting, looks like authors make the body very short by putting more into the abstract. The ones I briefly skimmed had no tables/figures, so its apparently not for empirical studies (although one could publish the data separately, which is a thing now). – Paul Nov 16 '19 at 02:27
  • @Paul I think the point here was that the results need to be interesting. If the calculations from N=10 to N=20 just develop an expected curve a little further along the X axis that might not be that interesting... If they, however, bring something new to the equation, e.g. showing that previous assumptions about the problem/solution were wrong, the that very much is interesting and publishable. It's really not about the length of the paper... – fgysin Nov 19 '19 at 06:58
  • A good example would be the following paper: Lander, Parkin. Counterexample to Euler's Conjecture on Sums of like Powers, https://www.ams.org/journals/bull/1966-72-06/S0002-9904-1966-11654-3/S0002-9904-1966-11654-3.pdf. There an interesting example was found using computing power which was not available at the time of the conjecture. However, the paper does not contain further information on the problem or the method. – Jannik Pitt May 16 '23 at 13:47
28
Papers like this can be published, and can be extremely important
There is no inherent reason why a paper of this nature would not be publishable, and indeed, there are some examples where papers of this nature have been published in high-ranking journals and have been extremely important papers. Whether a paper of this nature is publishable largely depends on the importance of being able to compute outcomes of the problem to a higher level. In some cases this will be unimportant, and the paper would be rejected; in other cases it would be extremely important, and the paper could become an important work in the field. Note also that the mere fact that the additional computation does not involve "anything special" from a theoretical standpoint, is often quite irrelevant to the importance of the result.
The most obvious example I can think of here is Shaeffer et al (2007) Checkers is solved. This paper was published in the prestigious Science journal. It extended earlier works computing the game-theoretic solution to the game of checkers. In this paper the authors had managed to obtain sufficient computing power to (weakly) solve the game, and this was a major innovation in the game-theoretic analysis of checkers. According to the authors:
The effort to solve checkers began in 1989, and the computations needed to achieve that result have been running almost continuously since then. At the peak in 1992, more than 200 processors were devoted to the problem simultaneously. The end result is one of the longest running computations completed to date.
In this particular case, the additional computing power accruing over time made the difference between early calculations that could not solve the problem, and later calculations that constituted a solution. This particular paper only weakly solves checkers (meaning that it gives perfect play from the starting point of the game, but it does not give perfect play from every possible board state). The next expected innovation would be to strongly solve checkers (i.e., find perfect play from every possible board state), and I imagine that the team that does this will also get an excellent publication in a high-ranking journal.
Ben
  • 68,453
  • 142
  • 263
  • I don't think the Checkers paper is an example, as they did develop new methods in the paper, the result was not obtained "simply by having more computational power". – JiK Nov 13 '19 at 12:45
    @JiK: From reading the paper, it does not appear to me that there is much (if anything) in methodological innovation over the previous runs. The paper cites previous literature that establishes the method, and also cites previous papers that used that method on checker boards with less pieces. So the method for the computations was developed in earlier papers, and already applied to smaller versions of the problem. The advent of greater computing power then allowed the computation to be run for a board with all the pieces, resulting in this paper. – Ben Nov 13 '19 at 12:54
13
In addition to the excellent answers that have already been given, the question indicates to me a common misunderstanding what papers actually are. They are, or at least should be, the communication of ideas, results, or some other type of knowledge that may be of interest to others. They are not badges of honour or grades or brownie points for doing X atomic units of research. In that sense, "how much work was it?", "how difficult was it?", or even "how large is the delta to existing work?" are fundamentally not the right questions to ask when evaluating whether something is publishable. If you have a stroke of genius and write down a cool idea very quickly, it's value to society is in no way diminished. Conversely, spending a lot of time on a bad idea does not make it more valuable to society.
However, as I wrote initially, it's an easy mistake to make because there is, of course, a correlation between effort/complexity and value/interestingness. Simple ideas are not often extremely valuable, because the chance that somebody else had the same idea before is high.
Apply this thinking to your question:
Doing "anything special" isn't in truth what makes papers accepted. If there are interesting effects to be observed for N=20, then go for it. That said, to my ears it does sound a bit suspicious that all that was needed to resolve an open question that people actively find interesting is to throw a little more hardware at it. I would make quite sure that indeed nobody has done it and that there are indeed interesting effects to be observed (and then I would still wonder a little why nobody has done it yet, unless the paper you build upon has appeared like a week ago).
Summarize the original work to the extent that is needed to actually follow your paper (given the setup this may be quite a lot more detail than what you would typically dedicate to previous work - that's ok, as long as you make it clear that these are not your new results). Describe your setup and experiment. Then, if the interesting results for N=20 are what should carry this publication, describe these results and in which ways they are interesting in a lot of detail. Connect them to previous results for smaller Ns, and, if possible, go to the bottom of why the results start becoming more interesting for higher Ns.
If that does not give you enough "meat" for a normal conference or journal article, there are alternative publication venues dedicated to shorter articles, such as journal notes.
xLeitix
  • 135,037
  • 46
  • 333
  • 493
  • Clarification: when I wrote the question, I intended it to mean that the interesting effects at N = 20 are predicted theoretically, so they might not be there at all after the calculations are done. E.g. when modeling a particle physics reaction, the results depend on how many small corrections one wants to include, and at some point it becomes intractably many, but when the experiments are precise enough then investigating the intractable calculations might be worth doing anyway. Maybe at N=20 the results are predicted to be precise enough to say if the theory matches experiment. – Allure Nov 21 '22 at 03:34
Dan Romik and Reinstate Monica have both given good answers. I'm going to give another answer with a slightly different emphasis with two points.
First, that there are specific journals which are often devoted to this sort of thing or close to it. One of those journals is the Journal of Computational Mathematics. That journal has a wide variety of articles, ranging from very pure number theory to mathematical physics ,but generally involving heavy duty computations.
Second, almost any paper which runs something for longer is going to be able to say something beyond just that they ran it for longer, and if I reviewed a paper, I'd like at least something beyond that. Explanations of any code tweaks they did would be one thing. Another thing would be any patterns they noticed in the data that wasn't obvious, or additional conjectures. Most of the time, if one is implementing something this way one is probably going to be thinking of the problem well enough that one will have at least something additionally novel one can say even if it is very minor.
JoshuaZ
  • 5,236
  • 29
What you say is not correct. According to my experience things are not as simple as what you think in supercomputers. It is not just simply copying and pasting the codes. The codes should be prepared in a completely different manner and need some adjusting and tunning in some cases. You do not have that much flexibility in coding in supercomputers as you have on your laptop. In fact, improving an algorithm and making it runnable in supercomputers is itself a challenge and might be worth publishing, even if the final results are not that distinctive.
KratosMath
  • 1,034
    @Aaron: so what if the code can get compiled? Unless the is written to use the supercomputer's features (like very wide buses for parallel floating point calculations, dispatch systems to run thousands or millions of jobs in parallel, etc), the program is wasting the supercomputer. Making an algorithm work on a supercomputer is a nontrivial effort and often worth publishing in itself. – nomen Nov 15 '19 at 06:23
    @Aaron I wasn't trying to be accurate. I was just trying to share my own experience, which is true in many supercomputers. Now I don't want to talk about the obstacles related to working with supercomputers. But the obvious point is that things are not as idealized as you have stated. – KratosMath Nov 15 '19 at 07:03
    @Aaron I think you are technically correct that the answer doesn’t strictly answer the question, instead it challenges the premise of the question by pointing out that it is in fact rare that one can squeeze better computational performance on a problem by simply compiling and running someone else’s code on a faster computer. But keep in mind that such “frame challenge” answers are very common on this (and other) stack exchange sites and can be valuable and add useful insight despite technically “not answering the question”. In particular I think this answer is interesting and upvoted it. – Dan Romik Nov 15 '19 at 14:25
  • @Aaron: that's what Kratos said and you "corrected". – nomen Nov 15 '19 at 22:01
    @Aaron: "What you say is not correct. According to my experience things are not as simple as what you think in supercomputers. It is not just simply copying and pasting the codes. The codes should be prepared in a completely different manner and need some adjusting and tunning in some cases. You do not have that much flexibility in coding in supercomputers as you have on your laptop. " Hope this helps. – nomen Nov 15 '19 at 22:19
  • @Aaron: I totally agree with you on this "If it took you a lot of effort to improve on the algorithm to make it run on a distributed network, then you might still be able to publish even if not in the way you think... or you might be able to publish twice". As a result, I improved my answer. I hope that clarifies everything. – KratosMath Nov 17 '19 at 21:07
I think the answer is determined by WHY such a study with N > 10 is conducted. E.g.
  1. Show off of computational power, for example, by calculating more decimals for Pi, beyond what is practically needed. About 39 digits are needed to calculate the circumreference of the known universe to the accuracy of a hydrogen atom. Calculating a Pi value beyond N = 40 is a sport with little scientific value per se.
  2. Attempt to test a hypothesis (derived from a theory, model, or experiment) that something interesting happens when N is in a certain range. For example, model a material structure consisting of more atoms, providing a better view on how such material behaves.
Both results are publishable!
The second example is inherently very interesting for publishing. Especially, if the results are significant.
The first example could be used to report recent advances in computer performance, report a novel method for scaling up resource-intensive computations, demonstrate the use of a supercomputer on a simple example, or raise public awareness of science and research.
There is also nothing wrong to replicate an earlier study, e.g. by demonstrating how certain algorithms scale from personal computers to supercomputers.
In your paper, you can summarize the earlier study, motivate your angle, and report and explain your results.
Eriks Klotins
  • 1,033
A lot of the answers already given are great but something that may help Bob make a decision about whether or not to publish a paper describing his results is to classify his methodology against other fields of research. In a more soft science, what Bob did would absolutely warrant a paper because there is a lot of difference between what he did and what Alice did, even if he followed her methodology to a T. From a hard science perspective, it may be better for Bob to contact Alice and see if they could collaborate on extending her existing paper or creating a new one if they find the scope is larger.
Since computer science kind of falls into a grey area of hard vs soft science and how Bob publishes his results should be based off of his interpretation of what methodology he used. A hard science result can be easily reproduced in the sense of X result was achieved with Y equipment and took Z amount of {time, temperature, pressure, etc}. If Bob had access to Alice's source code and did not have to make any changes to run on his supercomputer, this may be a situation where he would contact Alice to share his results.
If Bob had no access to Alice's source code and rewrote from pseudocode or basic descriptions of the program from her paper, this would very much be a case where Bob should have no reservations about publishing his own paper describing his findings. There is a varying degree of how well authors describe their methodology and even if Alice was very descriptive, Bob could easily find a difference between his methodology and hers if he had to rewrite it, even if it is not immediately obvious.
Ultimately, the decision is up to Bob. A lot of answers above have mentioned there is no harm in more papers and if the result N = 20 is truly interesting, it would certainly merit its' own paper for the knowledge that it would contribute. In my personal opinion, computer science is much closer to a soft science than a hard science. To truly prove some results, it has to be reproducible by many researchers from bare-bones methodology with relatively similar results for something to be conclusively true. There are so many moving parts involved in computers that it really is more comparable to a Psychology than a Physics.
Cloudzzz
  • 436
Its completely publishable and called 'secondary literature' (Which is different than secondary source):
It relates or discusses information originally presented elsewhere. A secondary source contrasts with a primary source, which is an original source of the information being discussed.
May fall under a review article too.
As a clarification: Secondary literature is material that interpret, evaluate, or analyze the evidence derived from primary materials and/or sources.
deags
  • 1,002
    This answer is wrong. Doing additional computations is not review; one is doing something beyond what is in the literature. Nor is doing additional computations purely discussion of pre-existing primary sources, since again one is doing something which those sources did not. – JoshuaZ Nov 13 '19 at 12:16
  • I think you might be mistaken about what a "secondary source" is. – Sneftel Nov 14 '19 at 08:42
    @ Sneftel I did not spoke about a secondary source. I spoke about secondary literature. – deags Nov 14 '19 at 16:38
