So for the past few months I have been printing in my Ender 3 and everything ran smoothly. But suddenly a few days ago I tried to print and the hot end temperature just keeps on rising past the set temperature of 230. I tried PID tuning, changing the nozzle, hot rod, and the thermistor nothing seems to work.... I even took out the main board and check whether the solder joints are loose, none so far. Any ideas on how to fix the problem?
Asked
Active
Viewed 2,414 times
Some things I can rule out: your nozzle is not at fault, and it is most likely a firmware thing. Some questions: 1) did you alter/swap the firmware? (You need to flash a bootloader iirc) 2) you print ABS or some other "hot" plastic? 3) can you use a [terminal](https://3dprinting.stackexchange.com/questions/10573/what-is-a-printer-console-terminal) and tell us at what temperature you get the max-temp? – Trish Mar 10 '20 at 07:54
Nope I have never alter or configure the firmware, for the print material I always use PETG, and for the max-temp it always blows out at 300. Maybe for extra information, I tried to bring the temp to 120 and it goes past that to somewhere around 210 then went back down to 100, then it just starts to fluctuate from 100-170. – Brilliant Purnawan Mar 10 '20 at 08:00
that sounds like really badly tuned, yes. I **strongly** suggest to swap the firmware, because at some point the ender-3 had no Thermal Runaway Protection. Maxtemp is a start, but we want proper TRP and PID-tuning, and that needs you to have a proper firmware. I point to 3 questions: [Bootloader w/o Arduino](https://3dprinting.stackexchange.com/questions/11338/flashing-a-bootloader-on-ender-3-without-arduino), [bootloader w//w/o arduino](https://3dprinting.stackexchange.com/questions/6685/how-to-install-new-atmega-firmware-via-the-isp-pins/6686#6686) and... – Trish Mar 10 '20 at 08:07
Hmm I guess ill try that first , thx – Brilliant Purnawan Mar 10 '20 at 08:08
...(Where is that last one...) [making your own firmware](https://3dprinting.stackexchange.com/a/6660/8884) - that last one is a step-by-step guide to get your firmware set up. You don't necessarily need a booloader even, but having one allows to alter the settingss much easier. Also, did you `M500` after the PID tuning? – Trish Mar 10 '20 at 08:10
This can't be your issue, but added for information, I once had the same issue when I installed a 12 V heating element in a 24 V system, overshoots and instability, replacing for the correct heater element fixed this instantly. – 0scar Mar 10 '20 at 09:02
Ah.. ill check it out 0scar thx for the input – Brilliant Purnawan Mar 10 '20 at 09:42
Ender3 is a 24V machine, so worth checking – Trish Mar 10 '20 at 11:06
