The first application I was shown of the calculus of variations was proving that the shortest distance between two points is a straight line. Define a functional measuring the length of a curve between two points: $$ I(y) = \int_{x_1}^{x_2} \sqrt{1 + (y')^2}\, dx, $$ apply the Euler-Langrange equation, and Bob's your uncle.
So far so good, but then I started thinking: That functional was derived by splitting the curve into (infinitesimal) - wait for it - straight lines, and summing them up their lengths, and each length was defined as being the Euclidean distance between its endpoints*.
As such, it seems to me that the proof, while correct, is rather meaningless. It's an obvious consequence of the facts that (a) the Euclidean norm satisfies the triangle inequality and (b) the length of a curve was defined as a sum of Euclidean norms.
Getting slightly philosophical, I would conjecture that proving that the shortest distance between two points is a straight line is looking at things the wrong way round. Perhaps a better way would be to say that Euclidean geometry was designed to conform to our sensory experience of the physical world: the length of string joining two points is minimized by stretching the string, and at that point, it happens to look/feel straight.
I'm just wondering whether people would agree with this, and hoping that I may get some additional or deeper insights. Perhaps an interesting question to ask to try to go deeper would be: why does a stretched string look and feel straight?
*: To illustrate my point further, imagine we had chosen to define the length of a line as the Manhattan distance between its endpoints. We could integrate again, and this time it would turn out that the length of any curve between two points is the Manhattan distance between those points.
This is false there are curves between two points where the Manhattan distance is larger than the shortest Manhattan distance between these points. even in "Manhattan geometry" the triangle in equality holds, see http://en.wikipedia.org/wiki/Triangle_inequality
– Willemien Jun 14 '14 at 21:53
