15
I did the following homework, can you tell me if my answer is correct?
Prove that for any $\sigma$-compact, locally compact Hausdorff space $\Omega$ equipped with a Radon measure $\mu$ the set of continuous functions with compact support $C_c(\Omega)$ is dense in the set of Lebesgue-integrable functions $L_1(\Omega, \mu)$. Remember that any point of a locally compact space has a neighbourhood basis consisting of compact sets. A topological space is $\sigma$-compact if it allows a countable cover of compact sets.
a) We may assume that $f \in L_1(\Omega)$ is non-negative. Why? Prove that for any $\varepsilon > 0$ there exists a function $s \in L_1$ of finite support such that $\|f−s \|_1 <\varepsilon$. You may use the fact that for any measurable, non-negative function $f$ there exists a monotonely increasing sequence of simple functions $\{s_n\}$ that approximate $f$ pointwise.
Answer a.1: Because $f = f^+ - f^-$ where $f^+ , f^- \geq 0$ and so one only needs the integral on non-negative functions.
Answer a.2: To prove that one uses that for any non-negative $f$ there exists $s_n$ such that $$\forall \varepsilon > 0 \exists n_0 : n > n_0 \implies |f(x) - s_n(x) | < \frac{\varepsilon}{\mu(\Omega)} \forall x \in \Omega$$ where $s_n \leq s_{n+1}$ and $\displaystyle s_n(x) = \sum_{i=1}^N \alpha_i \chi_{Y_{i,n}}(x)$ and $Y_n := \cup Y_{i,n}$. Here I think I need to assume $\mu(\Omega) < \infty$ but maybe that follows from what is given in the question.
Then $$\| s_n(x) - f(x) \|_1 = \int_\Omega |s_n(x) - f(x)| d \mu < \varepsilon $$
Now one has a measurable function with finite (and therefore compact) support. Next one wants to make that into a continuous function.
b) Recall the Theorem of Lusin and Tietze’s Extension Theorem:
Theorem (Lusin’s Theorem). Let $\Omega$ and $\mu$ as above and $f\colon\Omega\to\mathbb R$ a $\mu$-measurable function with finite support $E$. Then for any $\delta > 0$ there exists a closed set $K\subset E$ such that $μ(E\setminus K) < \delta$ and $f$ is continuous on $K$.
Theorem (Tietze’s Extension Theorem for LCH spaces). If $\Omega$ is a locally compact Hausdorff space and $K \subset \Omega$ compact then any $f \in C(K, \mathbb R)$ can be extended to a function on $C_c(\Omega,\mathbb R)$ with supremums norm bounded by $\| f \|_\infty$.
Combine these theorems to show that $C_c(\Omega)$ is dense in $L_1$. You may need that $\mu$ is Radon.
Answer b:
From a) one has a measurable function $s_n$ with finite support $Y_n$. To make it into a continuous function one can set it to be $0$ on $Y_n \setminus K$ where $K$ is a closed set such that $μ(Y_n \setminus K) < \delta$ for some $\delta$. Let's call this modified function $\tilde{s_n}$. Then $$ \lim_{n \to \infty} \| \tilde{s_n}(x) - f(x)\|_1 = \lim_{n \to \infty} \int_{Y_n \setminus K} |s_n(x) - f(x)| d\mu = \lim_{n \to \infty} \int_{Y_n} |s_n(x) - f(x)| d\mu = 0$$
Many thanks for your help!
Okay, but why exactly does it suffice to deal with $f^+$ and $f^-$ separately? The triangle inequality should be mentioned: for a given $\varepsilon \gt 0$ choose $s^+$ and $s^-$ such that $\|f^\pm-s^\pm\| \lt \varepsilon/2$ and then $$\|f-(s^+-s^-)\| \leq \|f^+-s^+\|+\|f^--s^-\|\lt \varepsilon$$ by the triangle inequality and the choice of $s^\pm$.
Here's a better and more direct way to do it (you don't say how to do it, after all!). Note that the following argument doesn't use $\sigma$-compactness of $\Omega$.
The idea (the basic idea of all of Lebesgue's integration theory!) is to slice the set of values of $f$ into fine strips of height $2^{-n}$:
Assume $f \geq 0$ and put $A_{k,n} = \{x\in \Omega : 2^{-n} k \leq f(x) \lt 2^{-n}(k+1)\}$ and consider $s_n = 2^{-n} \sum\limits_{k=0}^{2^{2n}}k \cdot[A_{k,n}]$. Then $s_n$ approximates $f$ on $\{x \in \Omega\,:\,0 \leq f \lt 2^n + 2^{-n}\}$ up to a precision of $2^{-n}$ pointwise.
Thus $s_n \nearrow f$ pointwise a.e. and since $f \in L^1$ we have $s_n \in L^1$, in particular $s_n$ is supported on a set of finite measure.
By the dominated convergence theorem, then, we have $s_n \to f$ in $L^1$: note that $\|f-s_n\| = \int f-s_n$ and $0 \leq f-s_n \leq f$ while $s_n \to f$ pointwise a.e.
But, as was stated in the exercise you may assume this fact, so there would be no need to spell it out.
The space $\mathbb{R}$ with Lebesgue measure is $\sigma$-compact (it is the union of the countably many compact intervals $[-n,n]$, for example) but it is certainly not of finite measure, so no, this does not follow from the assumptions.
What? I hope this is a typo. Finite measure certainly doesn't imply compactness, not even boundedness: the set $\bigcup_{n=1}^{\infty} (n, n+2^{-n})$ has Lebesgue measure $1$ is open and unbounded, so...
Added: Note that "finite support" should read "support of finite measure" here.
Theorem (Tietze’s Extension Theorem for LCH spaces). If $\Omega$ is a locally compact Hausdorff space and $K \subset \Omega$ compact then any $f ∈ C(K, \mathbb R)$ can be extended to a function on $C_c(\Omega,\mathbb R)$ with supremums norm bounded by $|| f ||_\infty$.
Well, it is certainly a good idea to recall Lusin's theorem and Tietze's extension theorem from time to time, but they are actually not needed here.
We have already shown that each integrable $f \geq 0$ can be approximated in the $L^1$-norm by simple functions with finite support. It remains to show that a characteristic function can be approximated by continuous functions. I'm not spelling the reduction to that fact out, because I should leave something to you.
So let $A \subset \Omega$ be a set of finite measure. Since $\mu$ is a Radon measure on a $\sigma$-compact space (hence it is inner and outer regular on Borel sets of finite measure), we can find a compact subset $K \subset A$ and an open set $U \supset A$ such that $\mu(U \setminus K) \lt \varepsilon$. By Urysohn's lemma we can find a continuous function of compact support $g$ such that $0 \leq g \leq 1$, $g = 1$ on $K$ and $g =0$ outside $U$. This gives that $\int |[A] - g| \leq \mu(U \setminus K) \lt \varepsilon$, hence every characteristic function can be approximated arbitrarily well by continuous functions of compact support.
Answer b:
From a) one has a measurable function $s_n$ with finite support $Y_n$. To make it into a continuous function one can set it to be $0$ on $Y_n \backslash K$ where $K$ is a closed set such that $\mu(Y_n \backslash K) < \delta$ for some $\delta$. Let's call this modified function $\tilde{s_n}$. Then $$ \lim_{n \rightarrow \infty} || \tilde{s_n}(x) - f(x)||_1 = \lim_{n \rightarrow \infty} \int_{Y_n \backslash K} |s_n(x) - f(x)| d\mu = \lim_{n \rightarrow \infty} \int_{Y_n} |s_n(x) - f(x)| d\mu = 0$$
I don't understand this argument at all, I'm afraid. What exactly is $\tilde{s}_n$ and how exactly does that limiting argument work?
Here's a suggestion: use Lusin's theorem to find a closed set of finite measure $K$ such that $\mu(E\setminus K) \lt \delta$ on which $s_n$ is continuous. Use inner regularity of $\mu$ to find a compact set $C \subset K$ with $\mu(C \subset K) \lt \delta$. Apply Tietze's extension theorem to extend the restriction $s_n|_{C}$ to a continuous function of compact support $\tilde{s}_{n}$,close to $s_n$ in the $L^1$-norm.
commenter
  • 1,666
  • I can guess what you intend in your Answer b:, but I want you to explain it to me, not the other way around. The idea should certainly be to use Lusin's theorem and Tietze's theorem, but you should be quite a bit more careful here. – commenter Sep 24 '11 at 18:49
  • Thank you! About the measurable function with compact support: the step function $s_n$ has finite support and therefore compact support. This is what I meant. – Rudy the Reindeer Sep 25 '11 at 05:33
  • What does "I should something to you" mean? – Rudy the Reindeer Sep 25 '11 at 05:35
  • @Matt: I meant "I should leave something to you". I'll fix it. By definition, the support of $g$ is the closure of the set ${x\in\Omega,:,g(x)\neq 0}$. You can arrange that each $s_n$ has compact support using inner regularity of your measure Radon measure (that's part of what you should exploit in b). However, "finite support" will have to mean "support of finite measure". Think of $\mathbb{R}$ with Lebesgue measure. A function with finite support has integral zero. – commenter Sep 25 '11 at 09:27
  • But if "finite support" is used to mean "support of finite measure" question a) becomes trivial: a simple function already has support of finite measure in $\Omega$. – Rudy the Reindeer Sep 25 '11 at 09:42
  • OK, maybe not : ( The sets in the support of $s_n$ are not compact : ( – Rudy the Reindeer Sep 25 '11 at 09:45
  • @Matt: Nobody said question a is difficult. I spelled it out for you because that's such an important technique. It is intended to remind you of this fact... As I said, think about the case of $\mathbb{R}^n$ where every function of finite support has integral zero, hence you can't approximate $f$ by functions of finite support in your sense. – commenter Sep 25 '11 at 09:49
  • What I still don't understand is: if I want to assume I have simple functions $s_n$ that converge to $f$ pointwise, without spelling them out, how do I get $\tilde{s_n}$ with finite support? – Rudy the Reindeer Sep 25 '11 at 14:50
  • Oh. That follows from $s_n$ being in $L^1$, right? – Rudy the Reindeer Sep 25 '11 at 14:56
  • Yay!! I get it! Finally!! Thank you! – Rudy the Reindeer Sep 25 '11 at 14:58
    @Matt: Sounds good, yes $L^1$ is the crucial point: this yields that $Y_n$ in your notation has finite measure. Do something like this: choose $n$ so large that $|f-s_n| \lt \varepsilon / 3$, choose $\delta = \varepsilon/2|s_n|_\infty$, choose an open set $U \supset C$ such that $\mu(U\smallsetminus C) \lt \delta$. Choose a Tietze extension $\bar{s}_n$ of $s_n$ and multiply it by a continuous function $0 \leq h \leq 1$ with compact support contained in $U$ and $h|_C = 1$. Put $\tilde{s_n} = h \bar{s}_n$. – commenter Sep 25 '11 at 15:08
    Then $$|f-\tilde{s}n|_1 \leq |f-s_n|_1 + |s_n-\tilde{s}_n| \leq \varepsilon/3 + \int{Y_n\setminus C} |s_n|\infty + \int{U\setminus C} |s_{n}|_{\infty} = \varepsilon.$$ – commenter Sep 25 '11 at 15:10
  • Do you not need to show that $h\bar{s_n}$ has compact support? – Rudy the Reindeer Sep 25 '11 at 16:25
    @Matt: I chose $h$ to have compact support, hence so has $h\bar{s}_n$. Sorry, I should have written $\delta = \varepsilon/3|s_n|$ above. Note that the the whole argument yields a sharpening of Lusin's theorem by proving that we can find a continuous function coinciding with $f$ on a "large set" (in terms of measure) and arbitrarily close in the $L^1$-norm (that's of course the point of the exercise :). – commenter Sep 25 '11 at 17:02
    Note that this is also useful for your other exercise on density of smooth functions in $L^1(\mathbb{R}^n)$. Just convolve $\tilde{s}n$ with a mollifier with $\varepsilon$ small to get a smooth function $g = \varphi{\varepsilon} \ast \tilde{s}_n$ of compact support close to $f$ in the $L^1$-norm. – commenter Sep 25 '11 at 17:08
  • Thank you! Of course, the support is not where the function is non-zero but the closure of that...! – Rudy the Reindeer Sep 25 '11 at 17:45
  • Actually, I wonder why the Tietze extension is needed. Once one has $s_n|_C$ continuous and $C$ closed (and therefore compact) I'm finished I think. – Rudy the Reindeer Sep 25 '11 at 18:47
    @Matt: As I said it is not strictly needed, but when arguing with Lusin, the set $C$ could be something genuinely horrible, like a fat cantor set, for example. We only know that $s_n|{C}$ is continuous (if we forget how we got it). Now we apply Tietze to get a continuous extension $\bar{s}_n: \Omega$, the measure of whose support we don't control in your formulation, so we cut its support down using $h$. As I said, we can get away with using Urysohn (because $s{n}$ takes finitely many values only) avoiding Lusin and Tietze. – commenter Sep 25 '11 at 20:32
    @Matt: Reading your last comment again, I should probably insist on the following point: a continuous function $h: \Omega \to \mathbb{R}^n$ is continuous on all of $\Omega$. Closed support $S$ and $h|_S$ continuous is not sufficient for $h$ itself to be continuous on $\Omega$. Why should $h$ approach zero towards a boundary point of $S$? (were $h$ continuous this would have to happen by definition of support). Think of a characteristic function of a closed set, for example. That's why you need something like Tietze to extend your function to a continuous function on all of $\Omega$. – commenter Sep 26 '11 at 12:29
  • thanks so much for your help! – Rudy the Reindeer Sep 29 '11 at 11:42
I fancied typing up the answer myself. As I'll leave commenter's answer accepted I don't think anyone should be bothered by this.
a) For $\varepsilon > 0$ and $f \in L^1$ we want to find an $s$ such that $\| s - f \|_{L^1} < \varepsilon$ where $\mu (\operatorname{supp}{s}) < \infty $.
We may assume that $f \geq 0$ because if we can approximate non-negative functions then we can approximate all functions in $L^1$. To see this let $f \in L^1$. Then $f = f^+ - f^-$ and we can find $s^+$ and $s^-$ such that $\| f^+ - s^+\| < \frac{\varepsilon}{2}$ and $\| f^- - s^- \| < \frac{\varepsilon}{2}$ and hence $\| f - (s^+ - s^-) \| \leq \|f^+ - s^+\| + \| f^- - s^- \| < \varepsilon$.
If $f$ is non-negative we know that there is a sequence of step functions $s_n$ such that $s_n \to f$ pointwise and $0 \leq s_n \leq s_{n+1}$. We need to show that $s_n$ also converges to $f$ in norm, i.e. $\| f - s_n \|_{L^1} \to 0$. For this we observe that $|f(x) - s_n(x)| \leq |f(x)|$ and $f$ is integrable hence we can apply the Lebesgue dominated convergence theorem: $$ \lim_{n \to \infty} \| f - s_n \|_{L^1} = \lim_{n \to \infty} \int_\Omega |f(x) - s_n(x)| d\mu = \int_\Omega \lim_{n \to \infty} |f(x) - s_n(x)| d\mu = 0$$
To finish part a) we need to argue that $s_n$ have finite support. But this is clear: $\int_\Omega s_n d \mu = \sum_{i=1}^N \alpha_i \mu(Y_i) < \infty$ implies that $\mu(Y_i) < \infty$ because $s_n \in L^1$ and $s_n \geq 0$ hence $\mu (Y_i) < \infty$ for all $i$ and therefore $\mu(\operatorname{supp}{s_n}) = \mu (\bigcup Y_i) \leq \sum_{i=1}^N \mu(Y_i) < \infty$.
b) Now for $\varepsilon > 0$ we want to use $s \in L^1$ with finite support and $\| s - f\|_{L^1} < \frac{\varepsilon}{2}$ to construct an $\tilde{s}$ with compact support and $\| \tilde{s} - f\|_{L^1} < \varepsilon$.
First we use that $\mu$ is Radon (and therefore inner regular) to get a compact set $K_\delta \subseteq \operatorname{supp}{s}$ with $\mu(\operatorname{supp}{s} \setminus K_\delta) < \delta$ for all $\delta > 0$. Then because $\mu(K_\delta) < \infty$ we can apply Lusin's theorem to get a closed set $C_{\delta^\prime}$ with $f$ continuous on $C_{\delta^\prime}$ and $\mu(K_\delta \setminus C_\delta^\prime) < \delta^\prime$ for all $\delta^\prime > 0$. A closed subset of a compact set is compact and so $C_{\delta^\prime}$ is compact.
Now we use outer regularity of $\mu$ to get an open set $O_\tau$ such that $\mu(O_\tau \setminus \operatorname{supp}{s}) < \tau$ for all $\tau > 0$.
And we'll use the following version of Tietze's extension theorem:
Theorem (Tietze’s Extension Theorem for LCH spaces). Let $\Omega$ be locally compact, let $K \subset \Omega$ be compact and let $f: K \to \mathbb{R}$ be continuous. For every open set $U \supset K$ there exists a continuous function $g:\Omega \to \mathbb{R}$ with $\operatorname{supp}{g} \subset U$ and $\operatorname{supp}{g}$ compact such that $g|_K=f$.
Then we can apply this version of Tietze's theorem to extend $s|_{C_{\delta^\prime}}$ to a continuous and bounded function $\tilde{s} : \Omega \to \mathbb{R}$ which is $0$ outside $O_\tau$. Then $$ \| \tilde{s} - f \|_{L^1} \leq \int_\Omega |\tilde{s} - s| d \mu + \int_\Omega | f - s| d \mu < \| s \|_\infty 2 (\delta + \delta^\prime + \tau) + \frac{\varepsilon}{2}$$
Where the second last term is doubled because an error might occur on each side of the support.
  • Dear Matt, I don't understand why $\bar{s}$ is continuous. You have a continuous and bounded function on the open set $O_{\tau}$, and you have simply extended it by zero. This typically doesn't result in a continuous function. (Think about the constant function $1$ on the open interval $(0,1)$, extended by zero to the entire real line.) Regards, – Matt E Jan 03 '12 at 19:57
  • Dear @MattE, thanks for pointing this out. I think it's fixed now. – Rudy the Reindeer Jan 03 '12 at 22:42
