This is known as the Tammes problem. For general $n$, it is a hard problem.
According to Conway and Sloane's book Sphere packings, lattices and groups, the optimal arrangement
for $n = 4, 6, 8, 12$ and $24$ are known:
- 4 : regular tetrahedron,
- 6 : regular octahedron,
- 8 : square anti-prism,
- 12: regular icosahedron,
- 24: snub cube
The book doesn't have the answer for $n = 20$ but it points out a regular dodecahedron isn't the answer. Furthermore, it is common the best known solutions for larger values of $n$ are not the (highly symmetric) candidates.
If you can get a copy of Conway and Sloane's book, look at the references there.
The info in this book is not most uptodate. Sloane has another book on similar topic (called Spherical codes) under preparation. I think I have seen a preliminary copy of it floating around the Web. In any event, look at Sloane's site for spherical codes as a start.
Update
As of July 2015, the Tammers problem for $3 \le N \le 14$ and $24$ has been solved. Following is a short list of papers for the solutions.
$N = 3,4,6,12$ by L. Fejes Tóth (1943)
Über die Abschätzung des kürzesten Abstandes zweier Punkte eines
auf einer Kugelfläche liegenden Punktsystems, Jber. Deutch. Math. Verein. 53 (1943)
$N = 5,7,8,9$ by Schütte and van der Waerden (1951)
Auf welcher Kugel haben 5,6,7,8 oder 9 Punkte mit
Mindestabstand 1 Platz?
Math. Ann. 123 (1951), 96-124.
$N = 10,11$ by Danzer (19??)
Finite point-sets on $S^2$ with minimum distance as large as possible,
Discr. Math., vol. 60, 1986, pp. 3-66.
$N = 13,14$ by Musin and A. S. Tarasov (2012,2015?)
Enumeration of irreducible contact graphs on the sphere,
Fundam. Prikl. Mat., 18:2 (2013), 125-145 [J. Math. Sci. 203 (2014), 837–850].
The Tammes problem for N = 14 (2015?) (preprint on arxiv)
$N = 24$ by Robinson (1961)
Arrangement of 24 circles on a sphere, Math. Ann. 144 (1961), 17-48
Edith Mooers has an survey article on Tammes's problem on 1994
summarizes all the solutions for $N \le 12$. An online copy can be found
here.
Together with Musin's preprint on $N = 14$, one should have a good
overview on the current status of the problem.
