Are limit points of a sequence and an interval differently defined? I ask because I've been given the following definition of a limit point:
A limit point is one such that every of its neighborhoods contains infinitely many points of the set other than itself.
If that is so then this criteria applies only when we talk about an interval and it fails to give limit points of any sequence - for instance $(-1)^n$ has limit points at $1$ and $-1$, but these are not limit points according to the above definition.
What's the discrepancy between the limit points of a sequence and the definition given above?
