I know that an integral domain with finite number of elements is a field, but, how do relate this with the finitude of the number of ideals?
user26857
  • 52,094
Hint: let $R$ be your integral domain, and suppose $\alpha \in R$ is nonzero. Consider the ideals $\langle \alpha \rangle, \langle \alpha^{2} \rangle, \langle \alpha^{3} \rangle, \ldots$. What must be true if any of these two ideals $\langle \alpha^{k_{1}} \rangle$ and $\langle \alpha^{k_{2}} \rangle$ are equal?
Alex Wertheim
  • 20,278
    This argument shows in particular that every Artinian domain is a field. – Crostul Sep 09 '15 at 16:30
  • that $\alpha$ is invertible? – L.F. Cavenaghi Sep 09 '15 at 16:59
  • Indeed, since (WLOG taking $k_{1} < k_{2}$) we have $\alpha^{k_{1}} \in \langle \alpha^{k_{2}} \rangle)$, so $\alpha^{k_{1}} = \alpha^{nk_{2}}$ for some $n \in \mathbb{N}$, so we have $\alpha^{nk_{2}} - \alpha^{k_{1}} = 0$. Now factor and use the fact that you're in an integral domain. – Alex Wertheim Sep 09 '15 at 20:24
  • This was exactly the proof I was looking for. – L.F. Cavenaghi Sep 09 '15 at 20:56
    @AlexWertheim, $\alpha^{k_{1}} = \alpha^{nk_{2}} b$, for some $b$. – lhf Sep 09 '15 at 21:56
  • Ack, you're absolutely right @lhf, my mistake. Fortunately, it doesn't change the reasoning too much... :) – Alex Wertheim Sep 10 '15 at 00:55
  • How does this prove that the given integral domain is commutative? – Prince Kumar Aug 06 '17 at 17:28
    @PrinceKumar: It does not. I am operating under the (standard) convention that an integral domain is assumed to be commutative. – Alex Wertheim Aug 16 '17 at 20:08
  • @AlexWertheim I had a questioj regarding the answer: $\alpha^{k_1}\in\langle \alpha^{k_2}\rangle\implies \exists b\in R,$ such that $\alpha^{k_1}=b\alpha^{k_2}.$ How to show that $R$ is field from here? If I factor things assuming, WLOG, $k_1\gt k_2$ holds then, we get $\alpha^{k_1-k_2}=b.$ – Thomas Finley Nov 02 '23 at 07:08
Let $R$ be your integral domain, and take $a \in R$, $a \ne 0$. We have to prove that $a$ is a unit.
Let $\mathcal I$ be the set of ideals of $R$ and consider the map $\mathcal I \to \mathcal I$ given by $I \mapsto aI$.
This map is injective (*). Since $\mathcal I$ is finite, the map is surjective. Thus, $R=aI$ for some ideal $I$ and so $1=ai$ for some $i\in I$. This means that $a$ is a unit.
(*) If $I$ and $J$ are ideals of $R$ with $aI=aJ$, then for every $i\in I$, there is a $j\in J$ such that $ai=aj$. Since $R$ is a domain and $a\ne0$, this implies that $i=j\in J$. In other words, $aI=aJ$ implies $I \subseteq J$. By symmetry, $J \subseteq I$ and so $I=J$.
lhf
  • 216,483
