I am trying to prove the following statement:
For all positive integers $a$ does there exists a positive integer $b$ such that $a^2 + b^2$ is prime? (If so, can we provide such a $b$?)
Given the connection between primes of this form and Gaussian primes, the above problem leads to the lemma:
Given a positive integer $a$ does there exist a positive integer $b$ such that $a+bi$ is a Gaussian prime. (If so, can we provide such a $b$?)
Based on the pictures generated of Gaussian primes, such as the ones shown in A Stroll Through Gaussian Primes, it seems to the case that this statement is true. (The pictures suggest that every vertical line in $\mathbb{Z}[i]$ contains at least one Gaussian prime.)
My current approach, which is somewhat of a longshot, goes as follows: a Gaussian integer $z = a+bi$ is a Gaussian prime if and only if $N(z) := a^2 + b^2$ is prime. Given some $a$, consider the Gaussian integers
$$z_n = a + ni, \quad n=0, \ldots, a,$$
and the corresponding norms
$$N_n := N(z_n) := a^2 + n^2, \quad n=0, \ldots, a.$$
These norms range between $N_0 = a^2$ and $N_a = 2a^2$. By Bertrand's Postulate, there exists some prime $p$ within that range of norms. The part that I was hoping could be proven is that there exists some prime $p$ such that $p = N(z_n)$ for some $n$.
Finally, here is a little Python code demonstrating that this is true for $a = 1, \ldots, 100000$:
%pylab from sympy import isprime from itertools import ifilter def find_b(a): """Returns smallest b such that a^2 + b^2 is prime.""" f = lambda b: isprime(a**2 + b**2) g = ifilter(f, itertools.count()) b = g.next() return b a = range(1, 100000) b = map(find_b, a) plot(a,b,'b.')
