Let the $ \mathbb F_{p}$ denote the finite field of $\mathbb Z/ p \mathbb Z$ and $\overline{ \mathbb F_{p}}$ its algebraic closure.
Now let $f(x)=X^p- b \in \overline{ \mathbb F_{p}}[x]$. I want to $f(x)$ has exactly one root. I know all is derivative are zeroes. How does that prove it has exactly one root?
Mohan
  • 14,856
Hint: There is an $\alpha\in \overline{\mathbb{F}_p}$, such that $f(\alpha)=0$. Show $f(X)=(X-\alpha)^p$.
MichalisN
  • 5,402
Working with derivatives is not a good idea here because the characteristic of the fields is positive.
As a hint: Do you know about freshman's dream?
Lennart
  • 537
  • No, I don't know about it. – Mohan Apr 01 '12 at 12:20
  • It says that $(x + y)^n = x^n + y^n$. This is not true in general, but if everything takes place in a field of characteristic $p > 0$ and $n$ is a power of $p$, then it is true. Can you now prove that freshman's dream is true in this case? Can you use it to solve your problem? – Lennart Apr 01 '12 at 12:29
  • Yes, I can show that.Then I can prove $X^p-b=(X-a)^p$ where $a$ is one solution of the equation $X^p-b$. – Mohan Apr 01 '12 at 12:33
