I'm trying to calculate $\sum_{k=1}^\infty\frac{1}{(4k-1)(4k+4)}$ using telescopic sums. I've already proved this equality: $\sum\frac{1}{(4k-1)(4k+4)}=\frac{1}{5}\big(\sum\frac{1}{4k-1}-\frac{1}{4k+4}\big)$. The problem is I can't cancel the terms of this sum.
I need help
Thanks
user42912
  • 23,582
  • Is there a reason to think you can turn this into a telescoping sum? Seems difficult. You might be able to turn it into a sum of logarithms. – Thomas Andrews Mar 31 '15 at 02:32
  • @ThomasAndrews The book I'm using suggested to use telescopic sums. – user42912 Mar 31 '15 at 02:33
  • According to Wolfram, the solution is $\frac{1}{40}(2-\pi + \log(64))$. Given that, I have upvoted you because I am curious how an answer like that is going to arise from a telescoping sum. – JessicaK Mar 31 '15 at 02:42
  • the sum can be expressed as $\frac{-\psi (-1/4)-\gamma }{20}$ where $\psi $ is the digamma function and $\gamma $ is the Euler constant – Lozenges Mar 31 '15 at 03:04
Hint: $S=\displaystyle \lim_{n\to \infty} S_n=\displaystyle \lim_{n\to \infty} \displaystyle \sum_{k=1}^n \left(\dfrac{1}{4k-1} - \dfrac{1}{4k+4}\right) = \displaystyle \lim_{n\to \infty} \displaystyle \int_{0}^1 \left(\displaystyle \sum_{k=1}^n\left(x^{4k-2} - x^{4k+3}\right)\right)dx= \displaystyle \int_{0}^1 \displaystyle \lim_{n\to \infty} \displaystyle \sum_{k=1}^n \left(x^{4k-2} - x^{4k+3}\right)dx$. Can you compute the integrand, and integrate it.
DeepSea
  • 77,651
