If $a$ is a complex number and you write $\sqrt{a}$ to denote a specific number, you have introduced a problem, as there are two complex numbeers whose square is $a$.
The problem shows up when you need to choose one of the two alternatives for all complex numbers at the same time, and this is unavoidable in some situations. For example, notice that for a statement such as
for all complex numbers $a$ and $b$ we have $\sqrt a\sqrt b=\sqrt{ab}$
to mean anything, we need to give sense to $\sqrt{a}$ for all $a$s.
A good choice for $\sqrt{-1}$ is certainly $i$. A good choice for $\sqrt{1}$ is $1$, of course. Now $\sqrt{-1}\cdot\sqrt{-1}$ is, according to these choices, equal to $i\cdot i$ which is $-1$. On the other hand $\sqrt{(-1)(-1)}$ is $\sqrt{1}$ and we chose that to be $1$; we have a problem.
Ok. Maybe we should have chosen $\sqrt{1}$ to be $-1$? Let's see what happens. Now $\sqrt{1}\cdot\sqrt{1}$ is $(-1)\cdot(-1)$, which is $1$, and $\sqrt{1\cdot1}=\sqrt{1}=-1$: oh no!
And you can go on like this...
Indeed, theere are four choices in all for what $\sqrt{1}$ and $\sqrt{-1}$ can mean:
| sqrt{1} sqrt{-1}
| 1 i
| 1 -i
| -1 i
| -1 -i
In each of these four options you can reach a problem.
