22
This post is a sequel of: Is the set of quaternions $\mathbb{H}$ algebraically closed?
This answer shows that:
1. $\mathbb{H}$ is algebraically closed for the polynomials of the form $\sum a_r x^r$
2. It is not for the polynomials freely generated by $\mathbb{H}$ and $x$, because $xi+ix-j$ has no root.
Question: Is there an algebraic closure (for the case 2)?
If so: What does it look like? What's its dimension over $\mathbb{H}$? What's its matrix representations?
  • What is a matrix representation of an algebraic closure? You mean, like an algebra representation over a subdivision ring of finite index? – rschwieb Dec 17 '14 at 14:22
    The "best" theorem I know for any notion of algebraic closure of $\Bbb H$ in terms of free-polynomials $\Bbb H\langle x\rangle$ is this: every polynomial in $\Bbb H\langle x\rangle$ whose highest degree term is a single monomial has a root in $\Bbb H$. The polynomial $xi+ix-j$ fails this because the part of degree $1$ has two pieces. But, for example, $xkx+xi+ix-j$ would have a root, since its highest degree is $2$ and it only has $xkx$ in that degree. – rschwieb Dec 17 '14 at 14:30
  • @rschwieb: by matrix representation I mean a representation on a vector space $V$ over $\mathbb{R}$, $\mathbb{C}$ or $\mathbb{H}$. – Sebastien Palcoux Dec 17 '14 at 14:37
  • @rschwieb: what's the reference for your theorem? Then, do you think that the closure is finite dimensional? – Sebastien Palcoux Dec 17 '14 at 14:40
  • I don't even know that it exists, and I have much less chance of knowing if it's finite dimensional over whatever field/division ring you are imagining. – rschwieb Dec 17 '14 at 14:42
    Sebastien, you want to read this paper by Lam on the quaternions for that theorem. It's an awesome paper for anyone interested in the quaternions :) – rschwieb Dec 17 '14 at 14:43
    It's not clear to me what "an algebraic closure" for the case 2 would mean, exactly. I presume that it should contain all elements that satisfy "polynomials" in the free product $\mathbb{H} * \mathbb{Z}\langle x \rangle$. Does it need to be a division algebra? Does every element need to satisfy a "polynomial" over $\mathbb{H}$? – Manny Reyes Dec 18 '14 at 01:36
I don't think that there can be an associative $\Bbb{R}$-algebra $L$, containing $\Bbb{H}$ as a subring, such that the equation $$xi+ix=j\qquad(1)$$ has a solution $x\in L$.
Multiplying $(1)$ by $i$ from the left gives us $ixi+i^2x=ij$, or $ixi-ij=-i^2x$. As $i^2=-1$ and $ij=k$, this reads $$ x=ixi-k.\qquad(2) $$ On the other hand multiplying $(1)$ by $i$ from the right gives us $xi^2+ixi=ji$, and using $i^2=-1, ji=-k$ this yields $$ x=ixi+k.\qquad(3) $$ The equations $(2)$ and $(3)$ together imply $k=-k$. As $k$ is a unit of $L$ this implies that $2=0$ in $L$, so $L$ cannot be an extension of $\Bbb{H}$.
Jyrki Lahtonen
  • 133,153
  • Sorry about being dense. Clearly $-1$ is in the center. I don't need to assume that $L$ is an $\Bbb{R}$-algebra for the argument to work. – Jyrki Lahtonen Dec 31 '14 at 20:06
  • Thank you! Now the natural question is the following: Is there a (non-commutative) polynomial $p$ (called "allowed") having no root on $\mathbb{H}$ such that there is an associative $\mathbb{R}$-algebra $L$ containing $\mathbb{H}$ as a subring and such that $p$ has a root on $L$ ? If no, then $\mathbb{H}$ is "in some sense" algebraically closed, else, what is its "allowed" closure ? – Sebastien Palcoux Dec 31 '14 at 20:16
    I'm not sure. $\Bbb{H}$ is in a natural way a subring of $M_2(\Bbb{C})$ with $1\mapsto I_2$, $i\mapsto \pmatrix{i&0\cr0&-i\cr}$, $j\mapsto \pmatrix{0&1\cr-1&0\cr}$. I would try to find a polynomial that has a zero in the ring of 2x2 complex matrices, but does not have one in $\Bbb{H}$. – Jyrki Lahtonen Dec 31 '14 at 20:23
  • Did you find one? – Sebastien Palcoux Jan 05 '15 at 08:57
It looks like the answer is morally "no." Now, there is a formal closure for which we can solve free polynomials: As in the case of fields, you take an inductive limit. Let $\Bbb H=R$ be our normed division algebra. Then
$$\overline{R}=\varinjlim_{[L:R]<\infty} L$$
where the inductive system is taken relative to inclusions of algebra extensions $L/R$ of finite dimension over $R$, each of the form
$$L_p=R\{x\}/(p(x))$$
where $p(x)$ is irreducible over $R$ and $R\{x\}$ is the polynomials freely generated as in case ($2$). This certainly has the required property that all polynomials in $R$ have a root in $\overline{R}$, and any other such object has a copy of this inside of it for purely formal reasons.
I note that the directed system so-defined is indeed a directed system--in fact a lattice--so this should go through unless I'm missing something obvious.
rschweib has noted that the result is no longer a division algebra, so this is really not ideal, but the "algebraic closure" property holds, and necessarily it's a minimal ring where this property can hold, so it seems this is the best we can hope for. However we also cannot force algebraicness of the result since $R\{x\}/(xi+ix-j)$ doesn't make $x$ algebraic appropriately in the sense that you want to mimic the field case's excellent definition that algebraicness means $F(\alpha)/F$ is finite dimensional as an algebra over $F$, which doesn't hold in this setting.
Adam Hughes
  • 36,777
  • Thank you! Do you think that $\overline{R}$ is finite dimensional over $R$? – Sebastien Palcoux Dec 17 '14 at 11:29
  • I think not, the same way you have the example of $xi+ix-j$ as irreducible of degree $1$, you should be able to construct "polynomials" of arbitrarily high degree which are irreducible. – Adam Hughes Dec 17 '14 at 11:31
  • If $\overline{R}$ is an associative division algebra over the real, then it must be infinite dimensional, thanks to the Frobenius theorem. – Sebastien Palcoux Dec 17 '14 at 12:04
    This would be the hope: that the same plan works for division rings. But there's still an awful lot up in the air. It isn't totally clear that $R\langle x\rangle/(p(x))$ does what we want it to do, or even if it's finite dimensional. $p(x)=xi+ix-j$ is a good example since $R\langle x\rangle/(p(x))$ looks like it might just be $R[x]$. Noncommutativity really throws a lot of wrenches into doing this whole scheme for $R\langle x\rangle$. – rschwieb Dec 17 '14 at 14:13
  • @SébastienPalcoux It looks like $R\langle x\rangle/(p(x))$ does not have to be a division algebra, so it seems unlikely that $\overline{R}$ is a division algebra. – rschwieb Dec 17 '14 at 14:18
  • Still, I guess the inductive system still exists, and indeed $p(x)$ has a root in the quotient ring, so maybe we get a remnant of what we wanted? It's been a while for me too, so I can't remember if the finiteness of the extensions in the inductive system is vital. – rschwieb Dec 17 '14 at 14:27
  • @rschwieb that's to ensure the extension can rightly be called "algebraic," mimicking the fact that $[F(\alpha):F]<\infty\iff a$ is algebraic. – Adam Hughes Dec 17 '14 at 19:14
    @AdamHughes Then maybe this really is the brick wall, since $R\langle x\rangle/(xi+ix-j)$ does not make $x$ algebraic, as was hoped. – rschwieb Dec 17 '14 at 19:36
  • @rschwieb Ah yes! Excellent observation. I'll update the answer to a stance on "negative, on these grounds." – Adam Hughes Dec 17 '14 at 19:44
    Do we know for sure that the result is not a division algebra? – Manny Reyes Dec 17 '14 at 19:48
  • @MannyReyes rschweib noted earlier that $R{x}/(xi+ix-j)\cong R[x]$ (at least probably), so it lacks an inverse for $x$ (for example). – Adam Hughes Dec 17 '14 at 19:50
  • @MannyReyes I for one don't have any idea what the proposed limit looks like. Maybe the quotients are all domains and the inductive limit is too? It would seem like a bit of a miracle if the whole thing was a division ring... – rschwieb Dec 17 '14 at 19:53
    You should be careful about how you define that colimit. For instance, if you take the diagram to include all injections between such extensions $L$ of $R$, the commutative analogue would be the zero ring for any $R$ that is not already algebraically closed (because it forces all Galois conjugates to be equal). As in the commutative case, you really want to construct a well-ordered sequence of extensions by induction (and for this reason existence of algebraic closures requires the axiom of choice in general). – Eric Wofsey Dec 28 '14 at 09:15
    Alternatively, you could take the colimit where the only maps you have are the inclusions $R\to L$ and you allow no maps between different $L$s. In this case, the commutative analogue will certainly not be a field (and you need to choose a maximal ideal of it to mod out to get an actual algebraic closure), and it is still not obvious to me that the noncommutative version gives a nonzero ring. – Eric Wofsey Dec 28 '14 at 09:31
    It is also not even obvious to me that $\mathbb{H}{x}/(p(x))$ is a nonzero ring for every nonconstant $p$. – Eric Wofsey Dec 28 '14 at 11:56
  • @EricWofsey: What's about if all the terms of $p$ are of the form $a.x^n.b$? And next, is there a non-trivial closure for such polynomials? – Sebastien Palcoux Dec 28 '14 at 14:12
  • I think Eric's right. Won't my argument show that we get the zero ring as a quotient ring easily? – Jyrki Lahtonen Dec 31 '14 at 20:01
