I've always wondered with flashlight apps, especially ones that use the LED light(s): Is there any risk of shortening the life of the LEDs? I noticed one app ("ASettings") gives a warning that doing so can "harm your phone"... which to me sounds even more ominous than burning out the bulb. I thought LEDs had a crazy long lifespan to begin with, so do I need to worry?
There's a really good thread of discussion about this on AndroidForums here.
In short, LEDs have a long life span (20k+ hours?). So the concern isn't really the LEDs burning out (although after a long period of time, they will eventually start losing the amount of output and their brightness will dim).
The real concern is to not apply too much voltage to the LED and overheat it. Another concern would be overheating your battery (due to heat dissipation from draining the battery from powering the LED).
In short, if you're only using the LED for time periods less than half an hour, you should be okay. If you need to use it longer, go get a real flash light. :)
- 21,906
- 20
- 78
- 98
Voltage is pretty much fixed for a given LED, the amount of light and the heat are determined by the current through the LED. – starblue Nov 10 '10 at 20:48
@BryanDenny Time for a necroQA. You mentioned "after a long period of time...", any idea how long? – End Anti-Semitic Hate May 02 '15 at 08:16
@rockpaperlizard it's a very gradual process and you won't really notice it. We are talking about tens of thousands of hours. When a bulb reaches its lifespan (20k, 50k, etc hours), the output will most likely be something like 70% or less of the original (new bulb) output. – Bryan Denny May 02 '15 at 12:28
1@BryanDenny Thanks so much. Does using it as a strobe (flashing on and off repeatedly at 30Hz-50Hz) change anything, or is that actually better for the LED because it's off half the time? – End Anti-Semitic Hate May 02 '15 at 20:42
@RockPaperLizard I'm not sure. Might be a better question for the electronics stack exchange site. I would assume that using a light on strobe would be better since the LED is on for less time. – Bryan Denny May 03 '15 at 00:55
LEDs do have a long lifespan (35K-50K hrs depending on the type of LED) but the issue is heat. The LEDs are intended to be used as a flash (ultra short duration) and probably don't have very robust heat managment systems if they have any at all. Each phone is going to be different. I would say that using it as a flashlight for a couple minutes tops is fine, but beyond that you run the risk of overheating which, depending on the type of LED and where it's positioned in the phone in relation to other hardware could damage the LED and possibly other components.
- 19,341
- 11
- 82
- 125
I use my LED for camera shots and also for lights and I have been doing so for almost every day or so and I've had my phone (myTouch Slide) for about 3 months now. Nothing has happened to it. I think if you're an avid user, you should just take care of it externally.
- 119
- 3
I have burnt my phone's leds with two of my previous phones. Pressumably because of those apps. I have never used flashlight continously not more than five minutes.
- 1
